I am using a simple select file ticket linked to a copy ticket in AE14.1 to copy a file to external server once a workflow is started. To be exact, I have a worflow set up to rasterize separations (rip), when I initiate the workflow AE scans the job URL for any pdf file containing the characters PRF. These files are our proof files and they are copied to a server that the pressroom uses for QC. So, sometimes our proof files will be revisions so the file would be named 1234-customer PRF R1.pdf. I set up the select file ticket to grab any pdf that contains PRF characters regardless of what rev it is. This works perfectly, the problem I am having is that in some cases a low-res version of that pdf sits in the same folder and it copies that also because it contains the PRF characters . We use QC software that compares the pdf proof to a sheet that is scanned from the press. Low-res pdfs could cause problems with that so I want to be able to tell AE to select all pdf files with "PRF" in them EXCEPT any that have "-lr" in them. We use a -lr to designate low-res. I am totally new to AE and it seems I should be able to use a regular expression to do this I just dont know how to. Any body have any ideas?
Currently my ticket is set up as:
Name Matches:*PRF*.pdf
I want to do something like this from the AE manual but want to select all files with PRF except ones that have -lr:
•To select all files except files where the name contains _report :
(?!.*_report).*@regex
