Re: Alternatives to Punisher I mean Publisher
Thanks Don -- a lot of our output is to a DocuColor 6060 and doesn't
require a lot of color mgmt -- pleasing color is good enough (esp to
Microsoft end users) and the Creo RIP we have has a pretty good conversion
from RGB to CMYK so this sounds like something I can let my customer
service reps use and/or recommend to customers for lower end projects.
Thanks for the testing and info!
>After opening the PDF, I preflight in Acrobat. All images below 300 keep
>their resolution. All images above 300 go to 300. All color is untagged
>RGB (DeviceRGB), meaning the RGB numbers will change appearance depending
>on the RGB profile used to display it (the default RGB profile in the
>program used). So since sRGB IEC61966-2.1 is used for Adobe's PDF/X-1a
>setting (or any other joboptions they have), the RGB I get from Microsoft
>via PDFMaker or PrimoPDF is untagged RGB that assumes the joboptions
>default RGB profile, sRGB IEC61966-2.1. If using PDFMaker, the conversion
>is done by Adobe behind the scenes so that the PDF is CMYK (default SWOP
>profile) when opened. If using PrimoPDF, I have to place PDF (which is
>untagged RGB) into InDesign (I use the sRGB IEC61966-2.1 profile there
>also by using the North American General Purpose 2 color settings, except
>turning CMYK color management policy to Off) and convert upon output to
>CMYK (default SWOP profile), or open PDF in Acrobat and convert to CMYK.
>Either way you go, you get the same result.
Sir Speedy Printing
1011 Burke Street * Winston-Salem, NC 27101
(336) 722-4109 * FAX (336) 722-5446
mailto:judyj@sirspeedywinston-salem.com
http://www.sirspeedywinston-salem.com
