Both are alcohol subs. APA is designed for use with continuous dampening systems and with FC1000 fount. Both are private label products. IDK who makes the ABDick stuff or the technical requirements. Though never mandatory and feel free to do as you please, but most subs are designed to be used with their fount counterpart. Some even designed to be used with varying levels of water hardness. All you can do is try. In consumables you generally get what you pay for. If you were satisfied with the APA then its worth the $50. Saving $50 but dealing with issues is not that cost effective in the long run. If it ain't broke....
Easier to add sub than remove, so you may wish to start at 1 oz of sub and you will probably never need more than 1-1/2 oz
