D
Deleted member 16349
Guest
This is another potentially interesting area that I think could result in simplifying the operation of the process.
From my limited experience and from what I have read, the application of water is an operational problem. Problems with inking of some rollers in the dampening system that should not be inking up, toning on the plate even if there is sufficient water being applied, monitoring ph and conductivity, contaminated fountain solution that needs to be disposed of, setting rollers, etc. It seems to go on and on.
Normally water is added very near the plate. There are many systems that do this now but from various technical papers and existing products on the market, water can be added into the system at almost any point on the press and the process of separating the image area from the non image area on the plate still works fine.
There are already spray dampeners that are used on web presses and there have even been attempts to use single fluid inks that already have the water in it.
One very good reason to have the water application near the plate is because it is far from the ink fountain. If one applied water high up in the roller train, there is more chance that it will disturb the ink feed on conventional presses.
But let's think of a press that has positive ink feed which is not affected by the amount of water applied into the system and where it is applied. Since the amount of water applied will have basically no great impact on density control, the accuracy of water feed is not as critical and the location of application is not so critical.
When applying the water near the plate, the dampening system must apply an even water film in order not to introduce printing quality problems. But if the water is applied high up in the roller train, this requirement for an even water film is not critical because the water will be worked into the ink by the roller train.
The dampening system could be as simple as a drip system that provides a controlled drip of water across the press. It could be a "one way" water feed and not require recirculation. Without recirculation, it would only be necessary to ensure the right chemistry in the fount solution is provided. There would be no need for monitoring and maintaining a recirculation tank and no need to dispose of contaminated fount solution.
Even the chemistry of the fountain solution for such an application might be formulated to be more environmentally friendly.
I have not done this type of testing but I see a potential to reduce the cost of offset technology and simplify the operation.
Just a thought.
Just a thought.
