AQ rinse water down the drain? Is this okay? H&B system / Ontario Canada
Slice
I am in Ontario Canada and am wondering if it's okay to let the AQ waste water from our LC1 go down the sanitary sewage drain (not the storm drains).
:confused:
Contact your local sewer district and ask them. Never second guess dumping things down the sewer. What might be OK in some area's and not allowed in others.
I would highly suggest if you buy your coating in Totes that you return your waste to an empty tote and have it disposed of in a safe manner. If you have ever scraped dried coating from a coater unit you can imagine over time thats what the inside of your pipes will look like after a while. Talk to your coating supplier and see how other customers are disposing of the waste.
AQ rinse
AQ rinse
AQ rinse water fails on a few parameters for sewer bylaws in Ontario. I have tested it many times. TSS and BODs (biological oxygen demand) are the main concerns. It will also cause some issues for you in the future with your drains. I had to clean out a few drains and offer solutions to minimize this from the drain for many of our clients as it is a compliance issue and a physical drain concern. [email protected] if you have any further interests for solutions. I too am in Ontario and can help.
