I have read the posts on this thread and would like your help to settle a debate I'm having on when GCR/UCR can be applied, as well as better understand how to calculate the economics of using GCR/UCR technologies.
Applying GCR Debate
I'm a newbie to the print world. My friend is a 20 year prepress veteran. My friend's experience is primarily in programs like PhotoShop, InDesign and Quark, but has experience in print workflows.
When I read about GCR/UCR tedhnologies, it appears to me the GCR/UCR formulas are generic to anything using CYMK inks. My friend insists that GCR/UCR is unique to images being converted from RGB to CYMK color space.
"Retain black (GCR/UCR) is something that happens when the RGB image passes through L*A*B where the black channel that did not previously exist is created before it goes into CMYK. You cannot apply retain black to an image that is already CMYK. To do that, you would have to convert the image from CMYK back to RGB, then BACK through L*A*B to CMYK again. "
[/QUOTE=pnkearns;101874]
Jahn comments -- Well, that would assume that everyone in the software development world would only be limited to using the ICC aproach, which is not always the case. Yes, it is very popular to use Adobe Photoshop to separate RGB files to CMYK using a custom profile - and this would pass that RGB image through LAB as the Profile connection Space (PCS) - using (most often) Adobe ACE (Adobe Color Engine).
One could also set up a workflow that consumes CMYK images, and then, pssing them back through RGB - or LAB - would make a new CMYK image.
Many Color management vendors do this "plus" some Look Up Table (LUT) conversions - so, this is sort of a hybrid approach - where they use Algorthms and image processing tricks.
At IQColour, we do not happen to depend ONLY on the ICC approach. We pass images through a unique and custom transform - and we also do not use LAB color space as the intermediate space, we use IJK and a custom space that can be read about under the Resources menu at the iqcolour.com web site.
Finally, the examples at IQ Color, Inc., posted in this thread earlier by Michael Jahn are all RGB --> CYMK, even though he implies he has done some CYMK --> CYMK work. So my friend may be right or wrong.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jahn comments - IQColour can convert RGB to CMYK, and CMYK to CMYK. I can post samples here I guess, but most of the samples I have posted thus far have been at the Sterling Ledet "colortheory" forum moderated by Dan Margulis.
Can GCR/UCR be done on an existing CYMK image to reduce ink?
-- why, yes - you can do this using Adobe Photoshop or many of the fine Device Link Profiles (DVL) offered by the many developers - just search Google for Ink Saver - Alwan, GMG, CGS and many others offer solutions...
Can GCR/UCR be done on either RGB or CYMK vector data?
-- why yes, absolutely - you could call this 're-separating'
GATF is cureently doing 2nd set of studies on this subject - they will be comparing different approaches and reporting on many factors related to ink savings and make ready times -- stay tuned !
