BackStage
Plucky07
Hi
I have a question about BackStage that I hope someone can answer:
When I run a workflow task from Illustrator using a report ticket we are finding that if we use
a Pantone colour ending in 'U' backstage is converting it to a C.
Example:
We produced a job that uses Pantone 485 U in Adobe Illustrator CS3 via Adobe's Swatch Libraries and then run a ticket that:
Normalizes the file --> Create's a ReportCard --> Print's it --> Creates a PDF 1.4
That then creates a PDF and prints it showing the ink now converted to Pantone 485 C.
Any ideas?
Re: BackStage
Hi
I am just creating a Normalized pdf and it does not having any option of what I can see.
I've tried the Export to PDF settings but it still renames the colour with a C.
Have you come across this problem as well on your BackStage Server?
Re: BackStage
As far as I know, Esko still doesn't have a Pantone Uncoated library. Try adding an ink to the Designer book exactly as you have it in Illustrator. Not a very practical solution, but it would at least let you know what might be going on.
Re: BackStage
Do you have a license of Packedge, or just Backstage w/ Illustrator clients? I'm not sure I've ever seen a designer book editor outside of Packedge...
Re: BackStage
I think I have found it.
On our Flex-Rip we have Kaleidoscope installed but not licensed and
yet if I open it up it has a Ink Book window and within this there is a designer option and Pantone Coated library.
We do have 1 x PackEdge station but can not find any ink books on this station.
I have emailed esko but have not had a reply as yet.
Re: BackStage
Yeah, Esko only seems to ship with the Pantone Coated library. I've asked about the uncoated book before, but that never really went anywhere. What I was suggesting was seeing if adding a color such as "PMS 485 U" into the designer book, then using that same name in Illustrator would even work...
Edited by: Bobby Congdon on Apr 28, 2008 8:13 AM
