Batch printing, slip sheets and tabs
bcr
Hi folks,
We do a lot of batch printing of folders of documents... Imagine a folder with subfolders of docs by category. We then print the lot in a given sequence.
Docs are separated by either slip sheets or custom tab sheets.
Currently looking for a more sophisticated automated workflow solution for this. Currently using a mixture of Print Conductor, Batch Print Pro Legal Edition and Fiery CWS/Jobmaster.
We often have to break jobs up (e.g. send largest docs to another printer whilst the main stack of documents gets a holding page inserted for the missing document).
Ideally such a solution would allow us to:
- keep track of which docs went to which printer (summary report).
- automate insertion of a 'holding page' within the main printed stack when large exception docs are sent to secondary machine,
- automate population of slipsheets including document filename as text
- automate population of tabs (either using filenames as base text for the tab or a custom list e.g. from Excel)
- give a clear tabular overview of the batch of documents with the settings per document
- give a clear tabular overview of the programmed tabs with easy means of editing them en masse e.g. apply new numbering scheme to them all, remove/replace/insert certain text
Grateful if anyone has any feedback or suggestions.
smartsoft cover
