Baum 31.5e Cutter
gtmo
Baum 31.5e
Would like to know if anyone with a Baum 31.5e Cutter have had issues with the electronics.
The machine was purchased new and has been problematic since day one. Is only 4+ years old.
Replaced the complete board while under warranty, but problems have continued. Replace another board with no success.
The latest is while cutting the machine will reboot out of the blues, get error "Reset of Keyboard/KC!" Acknowledge <861>
Has anyone had similar issues?
Here are the latest problems, the "Screen" is very light can not see very good - we had not replaced it since it was working ok and are afraid to keep changing things, the lates is
Machine will just "Re start" just for the hell of it, while you are in the middle of using it or not, if is just on it will re start several time while not in use.
Hi sir
Please measure: +5Vdc and -350Vdc Backligh very carefully for LCD display.
Of course measure this voltage in the power supply:
The tolerance must be there in 0.7% Up or down.
+24Vdc sensors, CU unit
+5 +12vDC For programming, CP2
+28vDC
Blessing
[email protected]
