Best way to print black and white photography
If you want to print the K image in K only, a trick I use often is convert to LAB and then use only the L channel to make the proper level adjustments. Get rid of A and B totally. This often works better than any grayscale profiles.
Time to revive this thread!
I've got a really perplexing one. I have a huge folding carton (10" x 3" x 10") that basically has a huge "gray" image (think ansel adams but with a crosshatch texture pattern and other photoshop effects) image completely wrapping it. Submitted to me in CMYK (SWOP). This has to go on mid-grade SBS paperboard.
While we are GRACoL - G7 gray balanced (offset) I'm leaning towards duo-tone centrally due to the nature of the stock. Anyone out there produced anything like this before? When I did art-prints years back we did most of the work like this with duotones/tritones. I've had mixed success with CMYK.
chevalier,
here's a Photoshop action I built for 4 color grayscale images. The idea is that you want to limit (eliminate) the CMY in the highlight to mid-tone range. In the shadow end the resulting color casts aren't as noticeable.
  • 4 color Grayscale.atn.zip
