motormount
Hi all!
Until recently we were mainly exposing azura ts plates with our suprasetter without any problems.
To reduse costs after a lot of trial and error,we are now exposing fitprimus positive plates and process them with a sirio 85 ctp plate processor.
Since the first set up,the blankets are not clear enough.
I've attached an image cause i can't describe it in exact words.
We've tested the plates with the nail remover plate tester
(that semi transparent liquid ladies use to remove the color from their nails,not quite sure how it's called) and plates are fine.
Also this thing isn't obvious in paper,it's only in the blankets.
Another thing is the white ''patches'' on the upper side of the plate,towards the end of the paper in the whole length of the sheet-there are four large of them in the image if you give a closer look-
They also don't cause any problems-at least problems we can see- but they are there in every plate in all the blankets!
Is any one experiencing similar problems?
Here's the link with a blanket i'm talking about.
https://www.dropbox.com/s/sulzd02pyqxylgy/2015-03-04 11.30.09.jpg?dl=0
Thanks in advance!
Thanks in advance!
