willvp2408
Hello. Just looking to see what is suggested to get started in blueprint and copying. 24”x36” house plans to posters. What is a good machine to do this?
Thanks for the reply. I know I want to be able to scan and copy. All of a sudden Epson is popping up in my fb feed. I won’t be doing a lot of prints to start. I will look at what HP has to offer and what is my service options.The HP PageWide XL line is the best on the market right now. Very fast, and it costs the same for color or b/w prints. You can get them with or without a scanner built-in. Though, if you're going to be doing alot of scanning as a service, you should get it offline so you can have someone scan while someone else is printing. If you think you will mostly be doing copying rather than scanning, then in-line is more streamlined.
All of the models are pretty much the same, with the exception of 8200 which uses larger-capacity inks that cost quite significantly less per mL.
The speeds range from printing 10 D's/min to 30 D's/min.
You have the choice of a top stacker (up to 100-page capacity) or a rear high-capacity stacker (up to 500-page capacity). This rear stacker is only available on the 5200 and 8200.
If you're just getting started and don't think you'll be doing high volume (or don't have a high budget), then a T-series plotter from HP will be much lower cost, but also much slower at only 2-3 D's/min. Certain models in this line-up also come with a built-in scanner.
Canon , Ricoh, and Epson all have machines similar to HP's T -series, but nothing that rivals the speed of the PageWide XL line.
The Epson T7270 with feeder is a good option.Thanks for the reply. I know I want to be able to scan and copy. All of a sudden Epson is popping up in my fb feed. I won’t be doing a lot of prints to start. I will look at what HP has to offer and what is my service options.
