This should be a simple question but the Xerox 800/1000 brochure is a bit confusing. Look below, is the base system 3,197 lbs or 2,200 lbs?
IOT Base Printing System (without RIP and/or feeding/
finishing devices):
–– 100" (W) x 44" (D) x 74" (H)
(2,540 mm (W) x 1,105 mm (D) x 1,865 mm (H))
–– Weight: 3,197 lb. (1,450 kg) (weight is without
toner, PC-UI)
•• Base Printing System (without RIP and/or
feeding/finishing devices):
–– 118" (W) x 46" (D) x 74" (H)
(2,995 mm (W) x 1,107 mm (D) x 1,865 mm (H))
–– Weight: 2,200 lb. (1,000 kg)
I'm thinking of the base system with the standard trays but NOT with the hi-caps, interface module, and finishing/stacking. What the heck does IOT mean?
Thanks,
Steven
finishing devices):
toner, PC-UI)
Thanks,
Steven
