Broken dot on plate and print
falvarado
Good morning to everyone:
I am experiencing broken dots when printing is done. It is not a sharp dot, with the loupe you can see it is all broken up. Could some one help me with possible solutions to it? When plates come out of the CTP, you cannot see it because we are using Kodak Thermal Direct Plates, and these are not visible. Once inks hits the plate, the dot is already broken up. We believe that this is the cause of a snowflake apperience in flesh printing. Our press is a M1000.
I would appreciate very much suggestions. Thank you.
Regards,
Falvarado
falvarado
Dear Alois:
We were using Kodak Sword plates, and we changed over to processless plates: Kodak Thermal Direct.
On the Sword plates we could see the dots, but on this new plate we cannot.
Our main reason was to excape from chemistry.
Regards,
Francisco Alvarado
DCurry
Dear Alois:
Regards,
Francisco Alvarado
That's one reason that my former shop chose Agfa AzuraTS plates - no developer (gum only), and you can see the image quite clearly before it gets to press.
BeauchampT
Falvarado,
Take a plate before running on press and wash with a developer (if you have any left around), or perhaps a solvent. This way, you can see if the dots are coming out of CTP this way or not.
Also, is it all your plates, or a specific colour? Could be an ink tack thing...
One last thought....try a different plate.
falvarado
We are still with the problem that the dot that the CTP is producing on the plate is giving us a broken dot, that at the same time gives us a snowflate look on the flesh of people images, would you have any suggestions to where to look for in order to overcome the problem?
Regards,
Francisco
STSTech
Image a plate and wash the plate off with water by hand. Once processed look and see if you have sharp dots. If they are sharp, then you have an issue with your Press. Chek wash and fountain solutions.
STSTech
Koenig & Bauer Video
Canon 2022
The Video You Really
Need To Watch
View The Video
