Interesting. You are right, the "High" in Quark terms actually created a lower quality PDF than the "Low". So, my initial rant was inaccurate. So, I guess it is just JPG compression, in general, that's the issue. Generally, I use ZIP or no compression at all.
Still odd, though. Even with the compression being Low, as in low amount of compression. The printed sheets looked noticeably bad and we rejected the run (at our cost).
Been there.
We still output from Quark to postscript and let Distiller or Prinergy generate the PDF's. LOL
The only problem is that Quark's flattening abilities is AWFUL. I've been burned a few times.
I've had good luck with letting Q export direct to PDF since Q7 - can't remember any real issues popping up as long as you keep the compression off (or find your own magic formula.) Quark can maintain live transparency now, too, but you have to set the Prefs to keep it live rather than flatten.
