Thanks for your input, we are a small press based in the Seychelles. Our primary business is a local newspaper as well as other general print jobs...our run lenghts are fairly small, use normal inks and the presses are sheetfed. We don't mind the safelights. The issues I was unsure about is the variety of plates available for the violet laser and also the maintenance cost for the thermal...I've been doing a bit of reading and it seems the laser life for the violet is longer and replacements are cheaper...not sure how true that is.
Great... when you want to see nothing on plate choose ThermalDirect.
Think that plate developing on press depends on fountain solution which is not design to develop plates. I saw founts which can't soften emulsion enough and founts which removes emulsion completly. But of course there are some situations when Thermal Direct works.
Trillian looks great also but almost similar concept is known from years as Amigo plate from Agfa. We will see if Trillian will be so good as mentioned in press release.
Regarding platesetter I understand that Kodak prefares thermal because they has no violet engines. If you want to say that Quantum head is cheap when you need to replace them I will be very surprised.
One is true, everything depends on company profile. Sometimes thermal is better solution sometimes violet. I think that good workflow and professional support is more important then only engine which is only a box of iron. Most of today platesetters from every supplier (Agfa, Kodak, Heidelberg, Screen) will produce good plates.
Thermal gives you a huge range of plate options though - especially with an "open" system like the ones Kodak sells. There are many dozens of thermal plate manufacturers out there, giving you a huge choice of suppliers. We have a standard program to qualify any plate that will technically work - as far as I know, that's unique in the industry.
Kevin,I'm always glad to help, of course. I hope you choose a Kodak solution in the end, but that's not the only reason I'm here!
Thermal Direct is Kodak's non-process plate - meaning that you take it out of the CTP and it can go directly to the press. There's no processor, no chemicals or wash-off, and no disposal of used chemistry. Quality is as good as many "normal" thermal plates - 200lpi or FM25 is not an issue. 100k runlength, good compatibility with various press chemistry, etc. The main differences (which I'm sure my competitors will point out) are low image contrast after imaging, and high exposure energy requirements.
In today's environment, visual inspection of the plates shouldn't be required. By eliminating the chemical development process, we've also eliminated the biggest source of variation - so plate measurement on a regular basis isn't really needed either. Of course we'd like more contrast, but there are thousands of users out there very happy with this solution today. The plate exposure shouldn't be an issue either if you look at system throughput. At least on a Kodak CTP, we have the power density to output at full speed on most of our normal-speed devices.
If processless isn't for you, then there are many other great options too - including our new Trillian SP plate (but it won't be fully available until July - Kodak Trillian SP Thermal Plates - Kodak Graphic Communications Group )
If you're looking for used Kodak devices - I'd suggest the proven battle-tank Trendsetter 400 is always a good solution unless you need automation. Used Lotems and Magnus devices are also great choices with full automation options... it depends on your supplier and local support.
Kevin.
Thanks Hessel for your advise...I will keep that in mind.Don't switch to silver, agfa is struggling with the quality of the silver plate at this moment. And i think it won't be long until they cancel the complete silver plate.
Thanks for the advise. I do feel more inclined to the Violet laser and presently looking at a 30mW.I suppose that someone is affraid that silver plates are only provided by Agfa. It's true, but the quality is excellent. Very high resolution (which is standard for silver halide technology), higher than any other digital plates. Run length is also high, up to 350.000 impressions. Canceling of production for violet plates are not foreseen in near future. Agfa produce so many sq. meters that this is not their intention to stop that business quicly.
Anyway, today violet engines should be equipped with high power diode (60 or 120 mW), enough to work with polymer or chem-free plates also.
It is no problem to switch from one plate to another, which is not common for Kodak platesetters.
Keep in mind that Kodak engines are "closed" and service intervention will be required if you decide to use different kind of plates in that system. AFAIK it cost a lot of money and nerves to force Kodak to allow use of "non-kodak" plates on their system.
