Hello yes we are having issues on flexo regaeding adhesion specialy black. My opinion is that we have wrong standard in use for flexo. I think we need to take 12647-6 flexo standard lab velues then trying to get as close as possible to dE for each cmyk color then meassure density and that should be our new density aim for each cmyk color. Becouse now im like dE=22 compared to lab values from flexo standard in black and it is way to black in my opinion k should have been a little bit grayish not rich black. Im just a printer this is only my opinion. Now that we bought a new machine i think we need to do this. But our prepress guys it is ok even if dE for instance in black is 22 and L is only 12 while it should be close to 26. I think that if we would do that procedure we wouldYou added a new thread post from your original on Nov 20?
The two topics are similar/related!
K is less important than CMY.
dE is only magnitude, not direction, (+/-L*). Are you too light or too dark?
Once you know that, do the basics with anilox (screen count, BCM volume), and ink viscosity.
So now it sounds like your concern is not about color, matching a target aim, but is about a functional ink problem, adhesion and scratching?
You mentioned UV inks, what is your sequence order, is K down first or last?
K down first will give it more UV light exposure/curing.
How many hours on your UV lamps?
Is your substrate a clear or opaque film? Is it surface print of reverse prin
Yes we have adhesion problems. But it is probably becouse we use offset standard on flexo print machine. Our pharmacetical customer want us to print density of black between 1.75 to 2.1. That is to high for low migration uv inks. The ink suplyer says 1.7 is critical for black. But if we use flexo standard for blak the anilox is muche lower and adhesion is muche better but density is out of the customers requirements. My point is that if we go to flexo standard we would resolve muche problems with curing in the future and prepress should be adjusted. The print with low migration inks is a disciplne and we should start by importing flexo standard.
