If you suspect your problem is on the ink roller and dampening side, consider checking those settings first to see if they are within recommended in specification. If not then you will going around in circles, you are fighting the press, and the press is winning. I often saw a lot of problems in the field where rollers were not set and gave the operator fits. Consider when the problem started and ask yourself what has been happening over time. If you were printing fine for 2 weeks and then the trouble started try an pin point any changes that you suspect. It could be a mechanical problem also, but try to solve the problem one step at a time. Consider getting help from professionals and also from experienced operators.. This can save you time and money in the long run.
