color check 101
Dario
Hi all,
just a general question...
How do you manage your color consistency in your printing environment?
Do you fingerprint every press run setup?
Then you use those icc profiles to color proof?
And then what?
How often do you check your machines?
What do you do to check the colors on the product? Color paches?
What else?
(please be verbose)
Thanks!
Magnus59
We used to fingerprint each machine and create an ICC Profile using Scitex Profile Wizard, but changed our methodology a few years ago, and now setup the presses to print to ISO standards, Calibrate our plotters to a baseline and proof using a FOGRA 39 profile. It's easier to maintain consistency this way, and if you outsource work to other printers who have also set their printing conditions up to ISO standards, you should also get consistent colours between your own plant and work printed outside.
Colour densities are checked on press with colour bars (in our case, they are Heidelberg specific) and Axis Control.
SteveSuffRIT
Calibration gets the color accurate, then process control keeps it consistent, repeatable.
Each press is fingerprinted with 3 stocks, gloss, matte, uncoated.
Purpose is to see how close or different they are to each other.
If close, average and use 1 plate curve for each paper type.
Use a generic not a custom ICC profile. Target ISO 15339 and CRPC
In theory, each press run is a mini-check. At SID & TVI, press should visually match proof.
Occasionally when paper space allows, print proof verification bar and check that.
Spot colors in live work, dE <=3.0
Process color in colorbar, SID +/-0.07, TVI +/-3%, Mid-tone spread <4%, Gray Balance dC
Dario
Thank you Steve!
How can you work with actual different ICC profiles and then color proofing using a generic one? (just asking)
Since you said "visual" therefore you don't "measure" anything, I suppose.
What do you mean by "SID" and "dC" ?
(sorry for my bad English)
Magnus59
Hi Magnus!
That's a clever way to work indeed!
...but what if your paper is out of Iso standard?
In the digital world you can calibrate a device for each paper stock, that's not feasible in the offset world.
We run to the solid ink densities we established when the colour expert commissioned by Kodak came and set up our presses and plate curves
SteveSuffRIT
Generic is for "close enough" dE'00 <= 5 @95%
No, you measure SID & TVI.
SID is Solid Ink Density, TVI is Tone Value Increase, dC is C* Chroma
SteveSuffRIT
The calibration is for not each different paper type, that's not necessary.
The calibration is for just 3 broad general groups, gloss coated, (satin,matte,dull), and uncoated
SteveSuffRIT
You can use Substrate Corrected Colorimetric Aims (SCCA), which is a mathematical conversion.
What About Profitability?
Canon
What about Profitability?
Offset yields new advantages
Read All About It
