Hello All,
Trolling for some opinions.....
Here is my situation, via a merger, we now have an in house printing plant. (previously used various commercial printers) At this new printing plant we have some serious limitations. IMHO it is due to a lack of equipment, knowledge and training, when I brought up some of my concerns to the plant manager, his responses were so confident it made me second guess my own knowledge and experience. (about 8 years pre-press, some minor press operator time, have gone through entire shop certification before)
Below are my concerns and the limitations now being enforced with what I think are correct responses/fixes.
The Setup:
Presses:
2 Heidelberg SM102's 4C early 90's I think...they are about as basic as basic can be, no IR dryers, and I am sure they are missing any other add-ons that may exist.
Plates:
Kodak Trendsetter, Kodak Gold plates
Ink:
Not sure, they have said it is Soy based
Paper:
Typically House coated sheet, IE Unigloss, 70# or 80#
Color management:
What's that? Literally.. not even a densitometer on the press floor that has been calibrated in oh about.. 15 years...
Limitations:
No more than 240 Ink density
Explanation given: Anything more than that and off-setting occurs
No more than 3 colors in any build
Explanation given: Off-setting and too hard to hold.
No continuously repeating elements in a single pub, particularly solids
Explanation given: Jobs are often split between the two presses matching them at all is nearly impossible.
If we ignore these limitations, and even sometimes when we don't, what we get is dulled out colors that sometimes do not match between signatures (meaning off by more than 5-10%) or even worse we recently we had a basic red build that was off from one side of the sheet to the other by nearly 30%. In short there is next to no consistency.
So left in this situation my graphic artists have, just shy of a full on revolt, not been too happy. Our customers have not been happy either, they can not quite put their finger on it, but they notice the change.
The solutions, at least as I see it:
Variance in single runs and between presses should be solved by a back to basics approach of finding the best "standard" densities for that press and running them, consistently. Start with something somewhere in the range of:
C 1.45
M 1.45
Y 1.0
K 1.8
From there tweak a little as required, with an aim of getting linear, within reason of course. Once those values are found, run them, everytime. With minor allowances here and there for occasional pain in the a#$ job.
Is that off-base? When I brought this up to the Press Manager I was literally laughed at... It sounds right to me, it is what we did and got certified. His response was, "There is no way you could ever run "standard" densities. From that, and best I can tell, they eye-ball everything and or use densitometers that haven't been checked or recalibrated in over a decade.
Off-setting is a bit of a puzzle to me. There are of course a ton of variables. The first thing that jumped out at me is the lack of IR dryers, or any kind of dryer, as the sheet drops. Do those IR dryers really have that much of an effect? I asked about their fountain solution and the inks and was again not so politely chuckled at, again am I off-base here? Best I know those are the places to start.
They have almost zero HVAC as well and print with the doors to the building open at almost all times. They are located in SoCal close to the coast, so humidity and temperature change often throughout a day. That to me is another big problem, that was kind of sluffed off.
This ia a monster post, so I will chop it off here. I am sure you can imagine the other issues that come up. Any and all insight is greatly appreciated.
The Setup:
Presses:
Plates:
Ink:
Paper:
Color management:
Limitations:
C 1.45
M 1.45
Y 1.0
K 1.8
