we've been having an issue of dropout with our QS for the past few weeks, initially it started as dropout on the 3rd magenta jetpack, i thought i had it sorted but it re-appeared on the first magenta JP, i started by swapping filters, connectors, tubing and eventually the jetpack itself, none of this worked until i removed the connector on the inktank, i thought the connector felt a bit loose so removed it from the tank and wrapped ptfe tape around the thread then replaced it back onto the tank,
From further tests and prints this seems to have done the trick, well almost, my problem now is the issue has appeared in one of the light magenta jetpacks!!!!
I can print without too many problems so's long as i print with heavy smoothing, if i try print with light smoothing its a waste of time,
Can anybody enlighten me as to what could be wrong with our printer as im starting to loose the power of rational thought
