Harley Man
Does anyone use Concentric dots on a sheet-fed press for packaging cartons. And if so how do you like it compared to regular dots. Any problems?
Harley Man
Harley Man
Why are you considering that screening method?
best, gordon p
I found a good explanation of concentric dots at www.highdefprint.com/concentricdot/htm
hope this is heplful to all.
That explanation is just a reprint of Esko's marketing material.
@Harley Man
This question has come up several times in this forum. So far, it appears that no one has done a measured comparison of the presswork performance of Concentric with AM/XM at the same lpi - e.g. 175 lpi Concentric against 175 AM/XM. (or 210 or 250 lpi). There are no published ICC profiles of Concentric and AM/XM at the same lpi - e.g. 175 lpi where one could compare gamuts. From my own testing - based on one Esko published sample - shows that there appears to be no significant difference in gamut between 175 lpi AM/XM and 175 lpi Concentric.
Have you made direct comparisons yourself? If so what has been your experience?
thx, gordon p
I saw a test sheet for a customer that has a pictorial with concentric 250 and regular dot on the same sheet and I have to say that the concentric does look sharper more detail.
But I have not run any tests.
Isn't one of the points of Concentric to enable the use of higher rulings. This is due to its intrinsic ink limiting characteristics.
In that sense, it is valid to compare e.g. 250 lpi Concentric with 175 lpi AM. It will indicate the benefits of Concentric in real-life configuration.
Harley Man
...it is completely fair to compare 175 or 250 lpi concentric to 175 or 250 lpi conventional AM/XM. If you want to stay with an AM screen and want to use 250 lpi - then compare 250 lpi Concentric to 250 lpi conventional. If you can't see/measure a meaningful difference then IMHO go with the 250 lpi AM/XM as it will be more forgiving on your imaging system.
best gordon p
Gordo,
If a printer is interested in Concentric, Esko Artwork suggests they first run our standard test form. This form is simple, no obligation and compares AM against Concentric at the same ruling. We look for a measurable benefit from this test - if the printer is not convinced then they would not continue with the project.
David (of Esko Artwork)
[SNIP]
Yes, Concentric can be challenging to plate making, when the equipment are not of good quality or condition.
[SNIP]
By it, it can be established whether or not the optical path of the customers recorder is of high enough quality to place sufficiently even exposure on-plate, and/or the plate and processing able to handle it, for the equipment to be able to utilise Concentric in the first place.
When the quality is confirmed (more readily on thermal recorders, LEDs close to plate; possibly more challenging to e.g. single-beam violet lasers. Their longer optical path is prone to misalignment, etc...), then the actual test measurements will be considered:
With the test form it will be established, what line width, number of rings etc. characteristics of Concentric will provide the best quality on that particular customers recorder-plate-press chain.[SNIP]
When the setup is done, Concentric should be no more challenging for plate makers to use in day-to-day production than FM screen of the same resolution.
From the printers point of view, it is even easier: More stable, more forgiving to ink feed variations during print run. And allowing to put more ink on solids, for best density, while limiting the amount of ink in screened areas, resulting in smaller dot gain and higher croma.
Of course, some these items apply to FM screen too.
[SNIP}
The inherent irregularity of any FM screen - by its very nature! - is far more easily detected as "graininess" by our visual cortex (that is exceedingly good at detecting shapes, by minute changes in tone.) This is the major drawback in FM, hindering its usability at lower resolutions.[/SNIP]
@Gordo
Enabling higher rulings is actually one of the major selling points of Concentric. (I could provide you with EskoArtwork presentations stating it.)
This comes from the ink limiting properties of Concentric Screen. When the same ruling is used, the screen dots of regular AM screen are carrying much thicker layer of ink. The concentric rings of Concentric (pun intended...) limit the amount of ink per screen dot, resulting in less dot gain due to ink spreading on/in paper. Simultaneously, some of the said spread actually takes place within the dot - in-between the rings. Because of this, there is less resultant dot gain and less coalescing of dots in mid-tones. Consequently, higher rulings can be used.
