Hello All,
We are beginning some testing using Esko's Concentric Screening, any of you USERs out there have any comments... Pros/Cons?
no sales pitches please, just anyone who has used it or tested it, please.
thank you, David
Make sure that you compare apples to apples. For example, using the same test elements, if you are testing 300 lpi Concentric compare it to 300 lpi conventional AM.
It would be great if you could post a low res image of the test form you plan to use so that folks could understand how you will be testing the screening.
thx, gordon p
This is would be great but your going to find that you don't need to print at a higher res then am to see a better printed piece. You will also find that Concentric will allow your press room more latitude with out the huge sift in color. Using the same testing elements is a great idea for sure. But I've found that in most cases printing around 220 Concentric will look far better then any 300 am, and your press room will think they are printing like it was 175... The Dot sweet!
thanks Kristian, glad you've had positive results!
We were looking at the 212 line screen ourselves, but we could probably go with 226.
Did you see any sort of pattern in any screen mixes or images?
Did you happen to have any gradients on your test?
thanks for your insights,
David
Kristian,
what was your output device and resolution (2540 or 2400), if you don't mind me asking?
thanks,
David
We have just completed the 1-col Concentric test on all of our substrates. This was to gives us common screening settings that we can apply to all substrates to keep it simple.
We have decided to go with 226lpi (we currently use 150 Paragon). This is for label printing and stocks such as 80g WLP and 30 micron clear and metallic films. Just by looking at the one colour we can see instantly that the Concentric gives a much cleaner looking result. We have already ran a 4-colour test job using standard setting from Esko and the results were great. Press guys said it came up to colour very quickly and seemed stable. Nothing but positive feedback from everyone so far.
Out next stage is to start profiling using PressSync. We also have GMG PrintControl and are going to try and combine the results. I will hopefully make a start on this sometime this week.
Kristian
Hi Kristian,
Have you run the PressSync calibration?
We are running the calibration here next week with circular (Euclidean) dotshape, 150 lpi, 2540 resolution.
Kind Regards,
RDC
