That video was not very impressive !
Callas pdfToolbox can properly convert the colors. They have a special button just for Office documents. Part of the logic is that they have developed will find TGB gray images and vector objects and put them in Separation Black. Plus they can find the RGB equivalents of the primaries in vector objects and convert them to their proper values. Those things don't happen in PitStop.
check out this video of how pdfToolbox does it's magic.
Created by Camtasia Studio 6
Hi Matt,
Did you actually watch this video yourself ? If you have, I am very surprised that you would suggest using this tool to convert greyscale RGB images into greyscale - the result is FAR to light to actually be in any way useable. I can't imagine any customer accepting the result.
I work with a company (IoFlex) that uses a algorithmic approach to convert RGB scans of documents which have color and black and wite images into the appropriate color space - that is, the software detects when it should segment and convert to CMYK or Greyscale or 1 bit tiff.
I took a moment to ask a Xerox filed rep and buddy what he suggests.
"If they have a FFPS on the 700 they can do page exception and set color mode to greyscale for just that page. Note that in greyscale mode you lose the grey gamma control that you get when printing greyscale INPUT in NORMAL color mode.
Conversion to grey in Pitstop can work if you have Pitstop color management set up right. I found a hack online that has you making a custom greyscale profile from, say, a GRACoL CMYK profile and loading that into Pitstop. I'll look it up. "
-load your favorite CMYK profile (GRACoL) then make a greyscale profile out of it, then load this in Pitstop color Mgt (have to figure out where to put it so Pitstop can see it..I forget..see what pitstop sees then search your HD for those....PC vs. Mac is different)
John Nate: How to color manage in a black-and-white world
not sure what they mean below "grey shadowing"....a bad JPEG is a bad JPEG...but the operative control point here is Gamma. note also that if you convert to greyscale upstream like this, then the "grey gamma" control on FFPS in Normal mode is in play for greyscale inputs and can further tweak greyscale appearance.
What DFE do they have on the 700? "
I will provide more details and build an example file this weekend and post it as a Google Doc
