Does anyone own a cp bourg sbm4 booklet maker and have problem with the face trim unit not able to face trim a certain amount of thickness. We are only running able to run 10 80lb gloss text sheet face trim with success. Anything thicker will trim and then freezes on the way down as if the blade is dull or not enough strength to cut the book.
Vic.
We have two and both are the same way. 2005 and a 2007
Vic.
