hello, has any one got a new xerox clour 550/560 with the external creo rip? i had a chance to test the external efi fiery rip and currently i am testing the creo external rip. to my surprise creo is not doing as well as i have expected - i think it has got something to do with the printer, because we have a creo rip with our xerox colour 1000 press and it works just fine and seamlessly, but the creo with the cx560 cannot rip almost anything and quite often it crashes. as much as i have not had very good experience with efi rips, the one a tested did very well, did not crash once and ripped everyrhing... what really surprised me was that our old integrated efi rip connected to a xerox dc 250 did process a file which the new creo failed to... has anyone had similar issues with this combination - xerox c550/560 and the creo rip?
as for the comaprison of creo and efi in general, creo uses better hardware and the "architecture" of the rip is more advnaced - you do not have to re-rip every time you change something in the job settings.
it is also said that the implementation of the appe on creo is better than on efi; they seemed to me both working fine.
both rips give you i think fairly the same amount of functions; however, there is one that i have not found on creo, but is on efi: the possibility of setting colour mode for exception pages in a job.
the speed of processing jobs was practically equal, creo was a few seconds faster in my tests (this did not include any vdp since this is not our concern for this installation).
user interface and control: it is often a matter of getting used to it and also of the set up workflow (you may have a lot of software tools and ways to work with files in pre-press so you do not need them in the rip...). personally i think efi's command workstation is more flexible than creo's interface - you can install it on every pc, use drag&drop for submiting files, you can select more jobs and change their settings simultaneously and this can be very useful sometimes.
for a production environment i would go with creo, but for a print shop with hundreds of small jobs and files a day i would choose efi (but only if i could test it for some time before purchasing it and see for myself that it is somehow stable and not full of bugs - this is unfortunately also typical for most of the efi products).
colour and image quality: i did not have any significant issues with colours or image quality in my test prints, colour was good (which is not to say exact - i did not demand it here) "out of the box" for creo as well as efi, i did not do any profiling. and i also did not have any large colour issues with any of our two efi fiery rips we have used (which i profiled and got good results...). there are minor diferencies between creo and efi in colour flow settings (and some really odd "solutions"), but it would be too much to discuss it here.
