Density standard
pacificiam
HI to All,
I don’t know how many times this topic has discussed on this forum. So I put new thread.
I used densitometer in that I found different reading on different filter.
I am bit confuse which density standard/filter should I follow.
I found some information on net in this they specified standards are use as per geographical location. Like ISO E use for Europe.
I want to know what is difference in ANSI E/ T/ I and DIN/DIN NB standards?
What is reason they divide as per geographical location? Is this related to there RAW material?
HI to All,
Status T / ANSI T: wide band color reflection densitometer response, used mainly in United States
Status E / DIN: wide band color reflection densitometer response, used mainly in Europe, main difference to Status T: higher values for yellow
Status I / SPI, DIN NB: narrow band densitometer responses, rarely used
The main responses are Status E (polarized) and Status T (unpolarized).
Related standards are: ANSI PH2.18, DIN 16536
AFAIK the geographic difference is due to different philosophy not raw materials.
best, gordo
Dear Gordo
This explains a lot
I have a Techkon SpectroDens device and I can choose out of these possibilities:
- DIN 16536
- DIN 16536 NB
- ISO/ANSI I
- ISO/ANSI T
- ISO E
The software explains about the European and the American standards.
But what is the difference between ISO E en DIN 16536.
I get the same measuring results when using them.
Thanks in advance.
best, gordo
Also Note that Status-T (INCLUDES PAPER) - MANY OF THE GRETAG INSTRUMENT'S SUBTRACT PAPER FROM THEIR READINGS.
Dan Remaley
