I've been reading through all of the available G7 how to documentation available and there's still two things that I can't seem to find definitive answers about. So this is a two part questions:
1) During the calibration press run, I know that LAB values are used to measure the individual solids to get within the G7 specifications. Those solid ink densities can then be recorded for baseline color. The LAB values provided for G7 are wet measured values or dry measured values? If dry, how can I adjust during a press run to get to the right LAB value for each ink color? Or is the difference between wet/dry ink LAB measurements negligible?
2) There are LAB values provided for G7 for coated papers. What about coated papers? How can the G7 calibration process be used for an uncoated sheet?
Thank you in advance for your help and responses!
