difference between :Elantrix S and :Elantrix SX?
Re: difference between :Elantrix S and :Elantrix SX?
Hello Evgeny:
The Elantrix SX is a newer version of our Elantrix S units, incorporating several design changes.
Here are some of the improvements..
• Improved control panel accessibility
• Added functionality:
o Plate counter
o Auto ON/OFF
• Clear separation of waste (left side) and fresh chemicals (right side)
• Improved gum section
• Improved replenishment algorithm
• Fill/top-up & replenish functions fully separated
• Modified developer circulation circuit
• Improved/reinforced drain systems (dev./wash)
• RoHS compliant
I hope this helps.
Steve, thanks you!
Is this processor equipped by brush?
Edited by: Johnson on Dec 20, 2007 5:32 PM
Hello again...
You can get a scrub brush as an option from the standard configuration, should you wish to clean-out plates like Amigo.
Please work with your local Agfa agent to meet your specific requirements.
Regards,
