I recently purchased a Igen5 classic (refurbished), and we are truly disappointed. I should mention that we also had two Igen4 machines, but the 5 is definitely worse. Unlike the 4, we can no longer hot stamp due to the fuser oil, and even double-sided tape doesn't stick! The image quality is rather poor, and finally, the white... No one informed us that to use white, we need to change the fuser unit and oil each time, otherwise the toner doesn't stick. And obviously, you can't use the second fuser for normal CMYK printing. In short, practically unusable. We are really disappointed and will try in every way to change the machine.
