aqazi81 Well-known member Nov 29, 2022 #1 Hi, Need to know which formula is correct for calculating distortion, as each one of these is calculating slightly different values.
S SteveSuffRIT Well-known member Nov 29, 2022 #2 Are these calculations from a trusted website (FTA) of from a custom written Excel spreadsheet? Mylar base (0.007") of photopolymer relief plate (0.067") is dimensional stable and will not stretch.
R rukspin New member Dec 2, 2022 #4 Dear aqazi81, can you share the excel file. I can adjust some values and the result will be the same.
aqazi81 Well-known member Jan 4, 2023 #5 rukspin said: Dear aqazi81, can you share the excel file. I can adjust some values and the result will be the same. Click to expand... I have attached the file, the main issue is the correct amount of distortion. Attachments Distortion Calculator.zip Distortion Calculator.zip 8.9 KB · Views: 636
A arkay_desai Well-known member Jun 9, 2023 #6 (Cylinder Size - K Factor (Different for each thickness of the plate) / Cylinder Size ) X 100
