doc 260 vdp mailing sorted
zBret
printing files from indesign CS4 or merge-data file to pdfs to print to doc 260
what barcode program will work the best with CS4 for direct mailings
example would be an 8up postcard vdp info, F&B, 13x19 sheet the is list 381 postcards, they need to print as sorted mail pieces then cut down and mailed.
Whats the best way to do this?
Ive done ticket numbering before on the doc 8 up cut and stack, very easy to do but never tried mailing just looking for some advice
Printable FusionPro Desktop will let you do variable out of an InDesign layout and put the cards in cut and stack order for mailing.
Ditto Fusion Pro Desktop. I use it almost daily, and it will do everything you need and lot's more. I couldn't work without it!
