Duplo + Fiery Impose
D0N0TR0N
I have a Duplo 618 and fiery impose. They are connected on the same network, I can publish files from my work computer to the PC controller that's connected to the Duplo. Connection is good. I have downloaded several Duplo presets from EFI Fiery's website. I added the .dbt business card file to the impose preset folder, and add the .j618 business card preset to the Duplo software. Same file name for both file types (.dbt, .j618), 12x18 24 up business card. I impose a business card, I load the preset that is now under the drop down in impose for 12x18 24 up business cards. It does it. I print it. I insert the 24 up 12x18 sheet into the Duplo, select that same job, 12x18 24 up (J618 file) on the Duplo and hit go. It cuts, but everything is off probably .25".
When I print a blank template for 12x18 24up business card it cuts that perfectly. I compare the uncut blank sheet to the one that has business cards and they do not line up. Gutters are different. I would assume since I have the same template in impose AND in the Duplo software it would impose where they should for that template and the Duplo would cut for that template. I am banging my head against the wall. The only thing I can think of (and I'm sure I'm wrong) is that the impose template file (.dbt) and the Duplo template file (.j618) are different.
Any input is appreciated.
