A ar17 Well-known member Mar 8, 2022 #1 looking for help how to convert existing dxf format to cff2. can't source in google how to save to cff2. thanks
M Magnus59 Well-known member Mar 10, 2022 #4 ar17 said: looking for help how to convert existing dxf format to cff2. can't source in google how to save to cff2. thanks Click to expand... A quick search found this GitHub - treeDiM/DXF2Diecut: Simple command line executable that helps converting a dxf file to either cf2 or ai (format used for diecut documents)
D Dahzee Member Mar 24, 2022 #5 If you contact this company, I think they do a standalone converter for CFF2 files. www.dvserp.de If you just need one file converted, post it here and I'm sure someone will convert it for you. Failing that if you have full Autocad you can get a developer to write an importer for you, the CFF2 spec. is available on the net as a .pdf document. Hope that helps.
