Editing Trim Box: Which software do you use?
shane8791
Hello! We have been using Prinect Geometry Control for years to edit PDFs. You can quickly change the trim box, media box, resize and split a PDF. The problem is it requires an expensive server and it's time to buy a new server again. We've begged Prinect to sell Geometry Control as a separate Acrobat plug-in but they do not. What does everyone use to view & edit a PDF's trim box & media box? We use hotfolders for imposition so the trim box is very important.
Thanks for your time -- Shane.
shane8791
Thanks for your replies! I've tried Prinergy & Pitstop to edit the trim box but still want something closer to Prinect's Geometry Control. We're going to try Callas now.
michaelejahn
um, okay, well - many imposition apps ignore these boxes ( as designers often do not understand what they are or how much bleed is required ( as there is no standard bleed amount from printer to printer ) - many imposition simply center the PDF into an imposition cell ( of if saddle stitch paginating, will simply move the objects for the cross over ) - so, maybe use an different imposition app ?
P_Crosby
Although I can only speak directly to Apogee Impose and Preps, I assume most all imposition software use the trim box for page positioning within the imposition. Apogee has had a Acrobat Plugin for years call the Docubox Manager. It was used even before Apogee Impose was available. It works brilliantly and it works in 64 bit environments both Mac and PC. It allows the user to manipulate in various ways all the boxes associated to a PDF page and/or pages in file.
Magnus59
If it is only geometry, I strongly suggest to understand the Acrobat built-in possibilities.
The built in tools leave much to be desired, I remember a time when you could edit the trim box in Acrobat by marquee selecting the area, however, Adobe took that option away. The Prinergy plugin is much more elegant than having to calculate the difference between the crop box and the trim size, especially when the trim dimensions are unknown. The Prinergy and Pitstop tools among others provide a simple interface where the page boxes can be visually dragged to the desired location.
Pitstop also has a default action to set trim and bleed box to marks.
InSoft
Learn more..
