We have an Epson 7600 that used to behave quite well. Until recently, when you load a flat sheet (not from roll) and you print to it, it will run a blank sheet through, and tell you the paper is out. The next sheet will start to print what you wanted in the first place. But you have to go through the loading of the "Ghost" sheet each time you spool something to print.
Anyone have an idea how to get this back to normal??
It runs off a Heidelberg Prinect System/Signa.
Thanx.
Thanx.
