epson 7800 printing problems help needed asap
hi all hope someone can help as need asap i have a epson 7800 i only do part time printing onto canvas i will include the adobe settings and the printing setting i have use this settings all the time and the results have been ok it is just a basic setting not profiled to the canvas last week it all went wrong with the colour i use pollyflex cotton and 3rd party inks i have use the canvas and inks for over a year so it is not the inks or media
the colour i notice are the greens, browns, are way off on the hair of people there is a brown blob hope you know what mean
please loot at attach hope you can see the colours
the nozzle check has been ok 7 out of ten are 100%
have done lots of power cleaning also the deep clean in hidden menu on epson 7800
adobe settings please look at attach files
View attachment Doc1.pdf
View attachment Doc1 2.pdf
View attachment Doc1 3.pdf
You need make new linearization and Icc perfil for new combination of Media and INK, if not need probe with other settings, may be use Mate or satin seting can help you.
in your driver setting under media settings (from pdf doc1 2) set the mode to custom and then to no color adjustment. In the photoshop print dialog set color handling to photoshop manages color and select a profile like pro9800 7800 canvas_pk or Pro9800 7800 EMP_PK with rendering intent to relative colorimetric. These are default epson profiles but they may be generic enough to work.
thanks i will try this and let you know first i have to get a set on ink to see if it that first also have you a website
Am asking this for a friend who has a 7600 or 7880, not sure which one. He says it won't print digital B&W negs so he can do platinum/palladium printing. He is not really computer savvy and has asked me about it.(blind leading the blind here)
So, anyone with one of these 7800 series know if they can be used with the clear film to successfully make enlarged negatives good for printing pt/pd and other Alt-process negatives? I am asking as he doesn't have internet access, only uses the computer for his photos.
_________________
Techstore are specialists in a range of Printing Services.
i am useing a polly canvas at the moment also cotton
Yes but which brand/supplier? We use Artbloc and they have done custom profiles for all our machines 7600/9600 and 7800/9800.
Adan, you need to know which machine as the profiles won't work with the wrong machine.
hi
hi
The Epson Stylus Pro 7800 is a wide format ink-jet printer. The printhead contains the nozzles that spray ink onto the page. If any of the nozzles are clogged or damaged, you will notice horizontal streaks or voids in your prints. The printer runs cleaning cycles periodically to maintain optimal quality, but you can run manual cleaning cycles if you want to fix a print quality problem. Cleaning the printhead tends to use up your ink, so be judicious and avoids cleaning the printhead unnecessarily.
