Hello.
Does Deskpack & Packedge plugins work in the same way that Artpro works in that you process your input pdf file and end up with a Normalized pdf at the end?
Trapped as well if you need to apply trapping?
First a bit of clarification.
Packedge is a standalone Windows based application for editing Normalized PDF.
DeskPack are a set of plugins for Adobe Illustrator (Mac or PC).
Yes both can, if you choose to include the options, trap, as well as provide several other tools to assist in working on your file and output a Normalized PDF.
You can download free trials of Deskpack plugins from here —> https://www.esko.com/en/support/down...trial-software
You can download a free plugin for Adobe Illustrator called Esko Data Exchange that will allow you to import and export Normalized PDF’s here —> https://www.esko.com/en/support/down.../free-software
Documentation for both Packedge and Deskpack plugins (as well as all Esko products) can be found here --> http://esko.com/support. Select the Product Documentation and then the product from the dropdown list.
