False CMYK color in 1PMS file
Tech
Very odd, when a paper-white fill text box with transparency is flattened against a 1 PMS background... it creates what looks like a false-positive CMYK when the PDF files is preflighted. Of course, no extra color shows up in output preview. Has this happened to anyone else?
Preflighted against what profile of what preflight application?
Can you post a sample?
Same InDesign layout export or print to postscript > distiller creates same result. PDF is then preflighted in Acrobat using our in-house settings and picks up 5 color plates in summary in each instance.
I'm guessing the is the usual transparency-and-spot-color-don't-mix problem. Our printer only accepts PDF 1.3-1.4. It looks this has something to do with flattening spot-text within paperwhite filled box overlaying a spot-color image background.
What is truly odd is that after preflight with show in snap on, it jumps to and identifies all spot-color text as CMYK.
I'll try posting a sample/screen when I have some downtime at work. I'll try export to v1.5 or higher and verify if this is simply a flattening issue.
Thanks for replying.
Just guessing, but Quark appears to define white as 100% RGB and Indesign as 0%CMYK.
Have you tried making the white box, 0% of the spot color?
