Flatworker 6
jimbozi
I had to re-install Flatworker and I cannot figure out how to reset the default measurements from MM to Inches.
Can anyone help??
Thanks.
Jimbo
Edited by: Jim on Jun 13, 2008 9:27 AM
Re: Flatworker 6
Hello Jimbo. We use flatworker 7 and to change the default to inches go to the tool menu and select setup Unit. I hope this helps.
Re: Flatworker 6
Okay I found a copy of flatworker 6.02 and if you open a template the setup units will be under the tools menu. Let me know if this works.
Re: Flatworker 6
Well, basically I had to open an OLD template I had saved. Set the units to MM. Save it. Re-open and set to Inch.
After doing that all NEW templates are now in inches.
thanks
