kewlbigdan
Not sure this is the correct forum. We are having issues with repeatability on a Flexo press with a Shrink material.
The issue is repeatability of the SID targets from one run to the next. Wondering if anyone has any insights.
We print highly decorative cosmetic shrink labels.
We have Esko based workflows, HD Flexo crystal screening, with microcell Pixel+.
Esko CDI and XPS systems.
Plate material is .045 Dupont EFX flat top plate material with associated FAST thermal processor.
Press is a MarkAndy P9 with LED curing, Siegworks Gracol13 UV Inks, 1000c 2.0 bcm Anilox rolls.
Print substrate is a Shrink material that is printed subsurface, KCMY rotation.
We have had 2 G7 Color experts (The guys that were part of the creation of G7), Plate experts, Ink experts all onsite to find a solution. This has been plaguing us for 9 months.
Fingerprints performed and all targets fall in directly with minimum maneuvering. P2P and TC1617 are measured and are 93% match to Gracol13 (CRPC6) standards. Curves are built and when going back to Verification 2 - 5 days later, the press set-up exactly per the tech sheet from fingerprint, everything checked, We cannot get back to the same Lab or density values on the SID targets without major adjustments to anilox, impression and falling outside the CRCP6 standards for 100/100/100 overprint targets.
We have done this multiple times over the past 5 months with same results.
We have checked ad nauseam; Esko rips, CDI settings, Plate material, Inks.
Any insights or help would be greatly valued. thanks
