FlexRip T4 and Hercules imagesetter
Possible.
Flexrip T4 will give you the 1-bit TIFF screened separations, you must choose a resolution supported on the imagesetter for output. However, EskoArtwork can not drive the Hercules directly.
If you do have the interface that comes with that imagesetter and it will accept the TIFF's then you are golden. If you do not have the interface, then try looking at a Raster Blaster (they support Hercules) and ask for a 1-bit TIFF catcher.
You can try to look Speedway Interface (5v PCI 2.1) interface card for your Herkules. Pls, don't forget to check engine firmware. Few years ago we have installed Esko FlexRip T4 + Speedway interface card. Raster Blaster is good solution, but we have used Q2/Imager software from HighWater.
