G7 for Indesign and Acrobat
rande
How should the color management preferences be setup for these apps? how would I keep the same color and/or setup for a PDF if i resaved it out of Acrobat. In other words, if i get a PDF from a client, how can I make the color the same as if I had the clients original and exported it out of Indesign? How are these 2 apps, color management sync d up? - thx
Another question I have is; Once a PDF is saved out of Indesign are the color specs, or profiles, locked in? Can we place it back into Indesign and change them, to say Gracol? or have a Gracol ICC profile in Acrobat and over ride the embedded profiles in that PDF?
You certainly should not place the PDF back into InDesign and use different PDF export settings.
Re-export the original InDesign document!
- Dov
thx - would using the same settings degrade it at all? We've had to add a QR code to an existing PDF and resave - thx
If you don't have access to the original InDesign to re-export a PDF, your next best bet is to use a tool like Pitstop to add the QR code into the PDF.
But then I would be saving out of acrobat. - so that keeps the same color info? Would I need to do anything in the Acrobat Prefs as far as color management to keep the PDFs original color info? - thx
