Gather questions and the answers on VDP software.
Shelia
Banned
I'd like to collect and submit our usual questions and the answers(see image) on VDP software here, for your reference, hope to be useful for you. my friends :)
1.How can come with the database entry like excel?
2. can the software do 2-sided variable data?
(1): Create a new template and connect to the data source:
(2): Design the template with two pages, one for the front and the second page for the back, see the image in detail:
Q: We use HP Indigo 4500 and VDP software, how long be able to deal with 1000,000 pieces of barcode or automatic SN?
A: less than 2hours and also you can output to PDF printer for check.
And you can also automatic generate serial number/date/random code, etc
Q:How to create variable images?
A:via below two ways (attached setup guide & preview)
1. “As is” handling uses field data to tell the Image Box what the image file name is.
2. “Trigger” handling uses the field data combined with a logic formula to create the image file name result. Both are used regularly for generating variable data.
View attachment How to print variable image-2.pdf
