This is a huge problem I've seen in both of my recent jobs. More at my previous job where most of the files we processed were PDFs. Although one job was a narrow web label printer, and my current one is at a sheetfed offset packaging printer, they both have a common thread. Artpro.
I really love Artpro, and think its great for the production environment. In both situations, we recieve files from a seperator or directly from the client. They then import the PDF into Artpro, do the prep work (trap, fix, apply dies/CAD, color correct images etc). They then ouptut to a proofer/rip either through Appletalk printers, or saving a postscript to hotfolders.
At the beginning, both printers were requesting PDF/X-1a. What I've quickly found with X-1a is, depending on the file, Artpro creates hundreds to thousands of Tiffs on import. A lot of times it is so bad, we cant even use the file. I usually see this when the file has heavy use of transparencies (drop shadows, blends, viginettes etc). I've usually alleviated this problem by coming up with my own set of standards for PDF submission. This usually involves PDF 1.6 or higher, embedded fonts, no downsampling, embedded images.
I'm not sure if any specific program is more guilty of bad PDF/X-1a files than another. We seem to have more problems with Quark, but InDesign also has a bad track record.
So, those of you who are importing PDFs in to Artpro, what specifications are you using? Do you also have problems with X-1a? I've recently become aware of the Ghent PDF Workgroup and plan on exploring their offerings. Any other suggestions?
