Getting rid of objects outside the Media Box...
StillWaiting
Is there a Task that will clip and get rid of all objects outside the Media Box (Margins) that is set in Illustrator?
Sometimes we get super complex files that we will just use a clipping box in Illustrator to visually eliminate anything past our standard 0.625" bleed. But AE still keeps those object and it gets messed up in the "Add SmartMarks" task because we have to have the "Fit Margins" box checked.
Hello,
I'm away from my Mac right now, so I cannot test this for you, but yes. (Kinda)
https://forums.adobe.com/message/5583061
As long as your illy doc has only one page
Pitstop Pro would also sort this out for you.
Let me rephrase the question. Is there a Task in Automation Engine that will clip and remove an object that starts inside the Trim Box and goes past the original 0.0625" bleed that I don't need?
Don't no why this was moved by someone the Adobe Forum. I posted in the in "Esko" section!!
