I'm not sure if this is in the correct sub forum, so apologies if not.
In short, my organisation contracts out a lot of graphic design work. Normally this is contracted out to external printers for printing.
We have an in-house repro and we're dipping our toes in printing some of the booklets etc in house.
Problem is we only ever have a PDF from the designer which might not be set up properly for us to print, or there may be errors which need to be fixed. Or we don't even receive the version for printing and just get a digital copy intended for use online.
I was wondering if it's normal/acceptable practice to stipulate with a graphic designer that they supply you with their working files, so that you can export them with your own desired settings, and fix errors, or whether there is a simpler way of handling this? On the other hand I get that the designers might think you want to re-work their files to create new content and cut them out.
I'm very ignorant about PDF standards and pre-press etc, and what we should expect to receive to print from. Conscious that I need to learn about that. I've also never used indesign, but one of my colleagues has a licence and I could have a bit of a dabble there.
Thoughts and advice much appreciated.
