I have also gotten information on the Formax Flashcard X, that seems fairly simple to use and doesn't rob the bank so to speak.
We would mainly use it for business cards and less often for postcards/invitations. The cassettes are somewhat limiting and could get expensive quickly if you try to do too much with this machine, I think.
Does anyone have experience with the Formax Flashcard XL?
The
Formax Flashcard XL looks to be a slight step up from the
Graphic Whizard PT 33SC only because it has automatic feeding. However, it is friction-fed and does not have blown air to separate the sheets. Prints from digital presses tend to have static, and are also quite slick from the toner, so the friction feed wheels tend to start slipping after a short period of time. I think you'll get frustrated with it rather quickly when it keeps miss-feeding. Also, if you do decide to get this machine, definitely get the cabinet with the larger waste bin because that little tray built in to the machine will fill up really quick. The 18" long side strips are especially problematic in small spaces because they will catch on the other scraps and bunch up.
How does the PT331SCC Air compare to the Duplo and AeroCut models - ease of use and pricing?
I haven't personally used any graphic whizard (GW) equipment, but the dealer out here who sells multiple brands of finishing equipment says they carry them for the more budget-concerned customers. Based on the units you're looking at, it seems like you're a smaller operation, and the
GW PT331SCC Air will probably do fine for your operation. I can't imagine it being any more difficult to operate than other brands - just a different interface to learn. If you search around on printplanet, you'll note from other discussions on this topic that many shops have the Duplo line, particularly their newest
618 model, and are quite happy with it. You can do a nearly unlimited variety of jobs, you won't be limited to any cassettes, you get vacuum feed with air-assist, it connects to your Fiery to sync the templates, and it's fast. I ran the older Duplo 616 for about 5 years at my last job, and it was very reliable and easy to use. At my current shop, we've had the
MBM AeroCut Velocity for about 5 years (which is now sold under the new model named
AeroCut X). It's been a great machine, and easy to use, but there are some minor things I liked better on the Duplo line.
In summary, you get what you pay for. I'd hate for you to invest $6,000-$9,000 to get one of those smaller units only for it to end up sitting covered in a corner collecting dust, and then having to spend more money to buy one of these nicer units in the end. I'm all for buying units cash, but remember that you can finance the machine too. You may be able to justify the monthly payment by considering how much time it will save having an employee standing at a guillotine cutter, and re-prints due to bad cuts.
