bjohnson1915
We're trying to find the cause of an issue that only appears after perfect binding, and I'd appreciate some insight from anyone who has seen something similar...
Setup:
• Digital covers printed on a Konica Minolta AccurioPrint C3070L
• 10pt C1S cover stock
• 1.2 mil DigiBond gloss laminate
• Covers look excellent and the laminate fully adheres while flat
• Lamination is done with a Duplo DFL-500
• Perfect bound on a Duplo DPB-500 with Planatol Planamelt Pro Hybrid adhesive
Issue:
• No visible adhesion failure on flat covers
• After binding, bubbling sometimes appears at the hinge/crease
• In some cases, laminate later begins to peel from the outside trimmed edge (not at the hinge, but from the edge)
• Problem does not show up immediately... it appears after handling and flexing, sometimes weeks or months later
We previously switched from standard laminate to DigiBond specifically to address adhesion concerns with KM toner. Adhesion has been excellent since the switch, but a client is now reporting a recurrence of the peeling issue on recently produced titles.
1. Has anyone seen hinge bubbling combined with edge peeling only after binding?
2. Could the heat from the glue we're using re-activate or weaken laminate adhesive near the spine?
3. Could the scoring introduce enough stress to start micro-separation?
4. Has anyone seen cases where the laminate appears fully adhered until after trimming, and then begins peeling from the cut edges during handling?
5. Is there any known interaction between KM toner, Digibond laminate, and post-binding handling?
I'm trying to determine if this an issue with the settings on our laminator (temperature, speed, pressure), a scoring stress issue, a binder heat/tension issue, or some interaction of all three of those. Any insight would be greatly appreciated!
Setup:
Issue:
