Heid DI rip reinstall
camasprinter
We had to reinstall our rip comp on a plus DI running Delta 7.5, were able to slavage data off old HD so that helped. We are up & running on the rip but the press & rip won't communicate with each other. Is there some setting that might have been missed that you might know of?
We had a Heid tech rep help & was a good help with remote and we were able to salvage all of the data off the old HD so set up theoretically went smooth but now we can't send jobs.
If we turn the press off we can see it go off & on on the network cards of rip comp and press so they are communicating. but it won't send jobs
Not sure the printer is set up as we can normally send jobs thru the workflow or directly. neither work.
If I try to set up the qmdi as a printer it isn't recognized over the network so something's up but we're scratching our heads. We think something is up with communicating, Another tech suggested starting the press up and watching the startup screen for a message and if we saw invalid drive specifications then there was an issue, that was the last message we saw before.
I'm thinking it's a simple setting to actually just get the printer recognixzed over the network but don't know ???
